engine oil in hydro
   / engine oil in hydro #1
GaryS
franklin park, pa
Kubota L3901 & LA525
While changing the hyro oil, I accidentally dumped in about a cup or two of engine oil. I've not started it up so I could drain it all out and replace with all hydro again if needed.
Is there any harm is having a couple cups of engine oil in the hydro? The transmission holds 7.7 gallons so it seems like a small amount.
thank,
gary
   / engine oil in hydro #2
that small amount I would not even worry about. Now if you has two gallons I would be a little more concerned.
Thanks, i kinda hoped that was the case but I wanted to be sure before firing it up and doing any damage.
   / engine oil in hydro #4
It won't hurt anything. In fact you could probably run all engine oil in there and it would not hurt anything. My JD skid steer specs engine oil for the hydraulics.
   / engine oil in hydro #5
i agree.
I run heavy equipment that you can put 30w or 40w engine oil in the tranny and 30w in the hyds.
I know lots of guys that used to be able to get 10w 20w 0r 30w cheap engine oil cheper than hyd oil and used it.
I wouldn't bat an eye at putting a lil new engine oil in the hyds.
heck.
on dusty mowing days when i am changing out the oil in the oil bath air breather cup 2x or 3x.. I won't hesitate to use utf in the cup if that's what I have handy.. :)
   / engine oil in hydro #6
Good question.... But no harm done at all!
2005 FORD F450 XL SUPER DUTY DUMP TRUCK (A51406)
2005 FORD F450 XL...
2013 CAT 246C (A47477)
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2016 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2016 FREIGHTLINER...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
2019 Freightliner M2 106 8.5 CuYd Street Sweeper Truck (A53422)
2019 Freightliner...
