engine oil in hydro
   / engine oil in hydro #1
GaryS
franklin park, pa
Kubota L3901 & LA525
While changing the hyro oil, I accidentally dumped in about a cup or two of engine oil. I've not started it up so I could drain it all out and replace with all hydro again if needed.
Is there any harm is having a couple cups of engine oil in the hydro? The transmission holds 7.7 gallons so it seems like a small amount.
thank,
gary
   / engine oil in hydro #2
that small amount I would not even worry about. Now if you has two gallons I would be a little more concerned.
Thanks, i kinda hoped that was the case but I wanted to be sure before firing it up and doing any damage.
   / engine oil in hydro #4
It won't hurt anything. In fact you could probably run all engine oil in there and it would not hurt anything. My JD skid steer specs engine oil for the hydraulics.
   / engine oil in hydro #5
i agree.
I run heavy equipment that you can put 30w or 40w engine oil in the tranny and 30w in the hyds.
I know lots of guys that used to be able to get 10w 20w 0r 30w cheap engine oil cheper than hyd oil and used it.
I wouldn't bat an eye at putting a lil new engine oil in the hyds.
heck.
on dusty mowing days when i am changing out the oil in the oil bath air breather cup 2x or 3x.. I won't hesitate to use utf in the cup if that's what I have handy.. :)
   / engine oil in hydro #6
Good question.... But no harm done at all!
1984 Ford LTD Crown Victoria (A52377)
1984 Ford LTD...
Payment Terms (MUST READ) (A50775)
Payment Terms...
2012 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Versalift SST40 Boom (A55218)
2012 RAM 5500...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
2018 FREIGHTLINER CASCADIA SLEEPER (A54313)
2018 FREIGHTLINER...
