engine oil in hydraulics
   / engine oil in hydraulics #1
mustang35446
buhl al
ih 1066
I have a ford 3000 that is getting engine oil into the rear end or hydraulic system,I need to find out how this can happen? The only way that I can tell by the IT manual is that the oil may be coming through the hyd pump.Thanks for any help.
Steve
mustang35446@msn.com
   / engine oil in hydraulics #2
Steve
That's pretty much the only way it can happen.
Ok can you tell me what to do to fix it? I have put a kit in it and it works great but is still putting engine oil in the rear end.
Thank you
   / engine oil in hydraulics #4
You have a leaking pump shaft seal. Nicked, installed backwards, whatever. Maybe the shaft is flawed where the seal rides.
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
2021 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2021 Ford F-250 XL...
12in Mini Excavator Tooth Bucket (A52377)
12in Mini...
2007 Ford F-150 Crew Cab Pickup Truck (A53422)
2007 Ford F-150...
2017 HAMM H10i SMOOTH DRUM ROLLER (A52706)
2017 HAMM H10i...
2025 International MV607 TMA Attenuator Truck (A52377)
2025 International...
