Oil & Fuel engine oil heaters
   / engine oil heaters #11
I don't trust road diesel to be properly treated against jelling due to low temps. I did once before, and only just once. (Called Hess station who gave me number for upstate fuel distributor who assured me their fuel was treated. I made it 20 feet out of the barn...)
Since then I add "the white bottle" Power Serve diesel treatment in the winter.
Cheap insurance, you don't want to mess with jelled fuel and filters.
   / engine oil heaters #12
I cut my diesel fuel with 20% kerosene when it is below freezing. Never had a problem when I add kerosene. My old Cub Cadet the fuel filter would gel up and the tractor would stop dead. My 2nd tractor a NH Boomer 35 I never had a problem as long as I added the kero. Now with my brand new NH Boomer 37 Cab I am using it during this cold spell. Give it a try. I do also have a block (freeze plug) heater that I use when it's in the 20's or below.
   / engine oil heaters #13
The dipstick heater was designed by a.............. dipstick.
Install and use a coolant heater . Either an immersion in block type or an external tank type . Look around , there should be a 120V male plug along side the engine for a block heater.
If the tractor was ordered without a block heater in NY. The tractor order sheet was sadly blotched .
The heating advice using heaters, blowers , torches etc is best ignored for your safety and avoiding fire insurance claims . Jackleg mechanic farmer fixes are just that.
Use winter diesel in the winter or the fuel filters will gell up with wax.
   / engine oil heaters #14
Hi Jimbo8264,
So what did you end up doing/going with your cold TZ25DA?
Did you heave that dipstick heater as far as you could?
BarnieTrk
By the way -- for my FORD 1720 here in mid-Michigan, it is not uncommon to see -10*F, but it's kinda unusual to see temps go much below that on a regular basis. When it's below 20*F, I am very happy using my block heater plugged in for 30 to 60 minutes before starting it. If I can anticipate running it in the afternoon or the next morning, I will operate the block heater with a timer, so it will come on an hour or so before I want to start the tractor. I also will let the hydraulics circulate & warm a bit, say 10/15 minutes before putting it to work. Lastly, I vote yes to using "the white bottle" of Power Service: Diesel Fuel Supplement +Cetane Boost | Power Service
Well long story short...learned how to properly start the tractor. switch is four position not three.... It is Off- on- preheat -start. Never put the switch in preheat. Did it right kicked right over at 15 degrees. My Bad......
   / engine oil heaters #16
I'm glad you learned and started doing what the book says to do - but, I would still suggest you go beyond the "proper" technique and install (if not equipped with one) and use a block heater for 30+ minutes when conditions are below 20*F and use a diesel fuel winter additive.
Just my :2cents:....... BarnieTrk :thumbsup:
   / engine oil heaters #17
How does the pad work at -30 C ?
I have got just below minus 20, the heat is there, and will heat the oil, I usually only plug it in for a couple hours before starting, I would think if you wanted to drive more heat into the tank or pan, you could also attach some type of insulation to the outside surface, I would think it would drive more heat into the fluid.
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A55745)
2015 VANTAGE...
2015 Ford Focus Sedan (A56859)
2015 Ford Focus...
Towable arrow board (A55973)
Towable arrow...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
Deere 335P (A53317)
Deere 335P (A53317)
2015 JOHN DEERE 35G EXCAVATOR (A52709)
2015 JOHN DEERE...
