? engine oil for 1500D?
   / ? engine oil for 1500D? #1
MartyH
Yanmar 1500D
What is an appropriate engine oil for the 1500D engine? One person suggested 15W40 Chevron Delo. To what standard do we need to match? I think the current is the star symbol. If it's appropriate for automotive diesel applications, is it appropriate for our tractors?
   / ? engine oil for 1500D? #2
Marty,
We use Texaco 15-40W in all of our tractors. It really depends a lot on what climate you live in. The colder it is, the lighter the oil should be. What I always recommend is that you ask a local dealer what they put in their tractors. If it is ok for automotive diesel engines, it will be ok for your tractor.
I did a little quick research and figured that Shell Rotella, Chevron Delo 400 or Penzoil long life would all be suitable. I found the Penzoil locally and went with it. 3 quarts of 15 W 50 went into my 1500D. It also received a Fram oil filter #3593 which has me a little concerned. While the Fram physically matches up, I don't think there is a pressure bypass in it. The Yanmar filter that came off was very heavy and looked like it had some kind of heavy spring bypass in it.
2015 HINO XJC740 BOX TRUCK (A52576)
2015 HINO XJC740...
2021 PETERBILT 389 MID-ROOF SLEEPER (A52472)
2021 PETERBILT 389...
BESTWAY LOT NUMBER 40 (A53084)
BESTWAY LOT NUMBER...
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
LOAD OUT INFORMATION LOT NUMBER 4 (A53084)
LOAD OUT...
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
