Oil & Fuel Engine oil change ?
/ Engine oil change ? #1
redka
Middle GA
Since I don't put enough hours on my tractor(5403) to change oil by hours, (about 50 hrs/year) I do it annually. The tractor is used almost none from October to April. Seeing some posts concerning how diesel combustion affects engine oil, I am wondering if it would be better to change oil in October so the tractor sits all winter with fresh oil in the engine, or change it in April before using it. So, is it better to sit through the winter with the used oil or with fresh oil....or am I overthinking this and it doesn't matter enough one way or the other? Thanks.
/ Engine oil change ? #2
Since I don't put enough hours on my tractor(5403) to change oil by hours, (about 50 hrs/year) I do it annually. The tractor is used almost none from October to April. Seeing some posts concerning how diesel combustion affects engine oil, I am wondering if it would be better to change oil in October so the tractor sits all winter with fresh oil in the engine, or change it in April before using it. So, is it better to sit through the winter with the used oil or with fresh oil....or am I overthinking this and it doesn't matter enough one way or the other? Thanks.[/QUOTE
It would be better to change it in the fall and let it sit with fresh oil. Oil with use will build up acids and moisture and the fresh oil will have neither. There may be some condensation freom the sit but that will evaporate when you go to use the machine.
[/QUOTEIt would be better to change it in the fall and let it sit with fresh oil. Oil with use will build up acids and moisture and the fresh oil will have neither. There may be some condensation freom the sit but that will evaporate when you go to use the machine.[/QUOTE]
That's what I was thinking, and will do. Thanks.
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A69167)
2001 FREIGHTLINER...
2018 PETERBILT 579 (A67714)
2018 PETERBILT 579...
x (A68191)
x (A68191)
Kubota L3901HST
Kubota L3901HST
2003 (INOPERABLE) CHEVROLET C7500 (A67714)
2003 (INOPERABLE)...
