Engine Oil change away from KUbota brand?
   / Engine Oil change away from KUbota brand? #1
TWD
Sierra Nevada Mountains - CA
Kubota M59
Anyone switched from the Kubota Brand oil 15w40 to T6 5w40?
I noticed my jugs of kubota 15w40 over the last few years are not identical oil types anymore so I'm not sure what may have changed... but I did notice when it's < 45*F it's noticeably rougher starting.
I have T6 5w40 on hand already as I use it in various other engines... thoughts? experiences ?
   / Engine Oil change away from KUbota brand? #2
What does your owners manual say for winter operating temperatures? that's the first place to look.
   / Engine Oil change away from KUbota brand? #3
I use T6 Rotella 5W-40 in my L3830GST and my RTV1120 because I use them year around. My ZD326 gets T6 in 15W-40 as it’s warm weather use only.
   / Engine Oil change away from KUbota brand? #4
Use the T6, your Kubota will thank you.
   / Engine Oil change away from KUbota brand? #5
All my diesels run T6 5w-40, 2 Kubota's and its a marked improvement on cold start.
   / Engine Oil change away from KUbota brand? #6
For engine oil I buy what's on sale - 20L pails of T6 work great
   / Engine Oil change away from KUbota brand? #7
T6 is all I run in both my Kubota diesels, as well as several other small engines
  • Good Post
Reactions: TWD
   / Engine Oil change away from KUbota brand? #8
Whatever oil meets the tractor specifications.
Different brands of oil are all bottled on the same production line.
   / Engine Oil change away from KUbota brand? #9
Kubota seems very restrictive in my owner's manual. But on their web site they clarify that weights over than 10-30 or 15-40 can be used:
Kubota | Lubricant & Grease Maintenance Schedule
I switched my tractor to 5-40 and it's doing fine. Have not had a cold start yet but I now keep a small milkhouse type electric heater in the garage anyway.
   / Engine Oil change away from KUbota brand? #10
I use that oil in my Dodge Cummins motor and cold weather operations are much better. IDK about small Diesel engines but I’ve been tempted to run it in my tractor.
  • Good Post
Reactions: TWD
2017 Dodge Grand Caravan SE Van (A50324)
2017 Dodge Grand...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
TMA (A49461)
TMA (A49461)
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2010 Ford Taurus Sedan (A50324)
2010 Ford Taurus...
