Mowing Engine Misfires while mowing
   / Engine Misfires while mowing #11
OKdokay -
Changed the fuel filter. Filled up the fuel bowl. Could not get it to start. Recharging battery. No joy. Will keep you posted. Appreciate any suggestions. Thanks.
Maybe air in the lines...try purging it some more?
Thank You.
Will take the fuel bowl and filter off again, check seals, purge, then will charge bowl and try again. Is it necessary to bleed/purge the lines going to the injector pump?
Starkiller
   / Engine Misfires while mowing #13
If needed
   / Engine Misfires while mowing #14
It is essential that the fuel lines to the injectors get bled properly of air. Air readily compresses so when the injection pump puts out diesel fuel under pressure, any air just compresses and nothing happens. The air compresses and does not open the fuel injector. Liquids under pressure will open the fuel injector - be it water, oil or diesel. Liquids cannot be compressed but gases can.
Bottom line is all air must be vented from the fuel line (loosen compression nut on injector to allow air to escape) or the injector will not be allowed to do it's job properly.
   / Engine Misfires while mowing #15
Father in law had a problem that was similar. More throttle would make it buck and snort at a higher RPM. He found a small crack in the top O ring on the fuel filter. Just big enough to suck a small amount of air, but it still started cold and ran, poorly that is. At this point on your tractor, I would crack all steel supply lines at the injectors/nozzles turn over engine and check for fuel. If the fuel has bubbles in it keep this up until it runs clear, no bubbles. If the bubbles persist, after a minute or more you are sucking air in from somewhere. If fuel clears up tighten fittings at I/N and start. Be advised: I am not a diesel mechanic, that's why I'm a TBN member!:thumbsup: Oh another thought, make sure you remove all old gaskets when replacing with new. 2 stacked o rings are not better than 1, and will suck air. Please don't ask how I know this!:ashamed: Let us know what you find, so we all benefit from this. Thanks and happy diagnosing. 445A
If needed
To new replies as well - Going over the tractor, found that the fuel valve from the tank was not bolted tightly to the firewall and had been wiggling around. It's a little cold here today so will wait until it warms up.
When I bleed the line at the injector pump, and at the injectors - can I just loosen the nut and press the paddle on the fuel pump to force fuel through the line?
Thanks
   / Engine Misfires while mowing #17
OKdokay -
Yeah, that's because air got in the lines while you were putting in the filter. Has happened to me more than once. Hard to avoid. Once you are sure that all the connections & gaskets are snug, go look for the priming pump. I could not tell if you were already using that. If it cranks well and still will not start, you are going to have to bleed the injector lines. Loosen the fuel line nut at the top of the injectors, one at a time and crank briefly until fuel squirts. Tighten that one back and go to the next one. It should then start and run. One hopes that is the end of the story. Let us know !
My thanks to all of you - Soundguy. MIB. George, murphy1244, doxford jim, 455A, and JWR....
Re-charged battery
Went back to fuel pump - used paddle.
Fuel still leaking and did not start.
Cracked nut on Delphi Fuel injector pump, used paddle, and retightened.
Turned engine over and it started :dance1:
Life is good!
Starkiller Hollow.
   / Engine Misfires while mowing #19
Great news. Sounds like your air leak was at/near the injection pump. That paddle (priming pump) only affects fuel on the low pressure side of the pump. Since that worked, no need to bleed all the injectors (this time.) You lucked out. On an older Kubota I had to bleed the injectors on the high pressure side of things. On a John Deere 4700 I had to use the primer paddle as you did. On my newer Massey Ferguson (and probably a lot of newer tractors) an electric fuel pump is involved which keeps pumping (and recirculating) fuel as soon as you turn the switch and before you crank. Those are said to be "self-priming" but that means on the low pressure side. Good luck to ya !
Final Answer -
1. Cleaned out fuel tank petcock valve. It was clogged. Drove down to gravel pit, loaded FEL and automatic furthest distance-from-house shutoff mechanism kicked in. :=(
2. Got it started later that night and drove back to shop.
3. Cleaned petcock valve again next day, drained tank, installed inline filter between tank and petcock valve. Checked at lift pump - fuel flow restored. :)
Starkiller
2366 (A58376)
2366 (A58376)
BARBED WIRE (A58214)
2007 NEW HOLLAND B95 BACKHOE (A52709)
2007 NEW HOLLAND...
MASSAGE CHAIR (A58214)
2024 DIGMASTER MINI EXCAVATOR (A58216)
2024 DIGMASTER...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
