Engine Misfire
   / Engine Misfire #1
401FordManNZ
New Zealand
Fords
Got the 7810 engine all assembled and running,idling well and runs well to about 1400rpm then goes to custard above this(blows bluey white smoke) and misfires,starts excellent and sounds healthy just no at rpms. I have checked the timing gears and rechecked them incase the camshaft was retarded or the like. The engine was stored for almost 20yrs could there be gunk in the injectors? Ideas most appreicated:confused:
   / Engine Misfire #2
Fuel timing is off. If not external to the injection pump, then the internal advance mechanism isn't working.
   / Engine Misfire
Thanks rick,Must be the internal advance,will check it out
   / Engine Misfire
Was fuel timing,rang the diesel&turbo guru and he suggested 25Deg btdc so reset everything and away! sweet as now. The simms inline pumps according to him, have no internal or external advance.
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
CABINET OF HOSE ENDS (A53843)
CABINET OF HOSE...
Hyster H225E (A47384)
2019 John Deere 3025E (A50123)
2019 John Deere...
2007 Mack 600 Day Cab Winch Truck (A53117)
2007 Mack 600 Day...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
