Engine Locked
/ Engine Locked #1
memotract
Ford 6610
In the process of doing something dumb with my Ford 6610 2 wheel drive tractor (trying to remove a tree stump with a box blade going forward at low speed & hi revolution) the tractor started blowing smoke/steam from bottom tube, I drove it 10' while engine kept loosing power and then turned tractor off thinking it was on fire. After letting it cool for 10 minutes, I tried to start tractor and engine did not turn, it made a loud noise. I turned tractor off and put it in neutral and let it rolled down hill to a flat spot.
Please provide information on the above issue, your help will be greatly appreciated.
Thank You
/ Engine Locked #2
The steam/smoke sounds like a blown headgasket, or possibly cracked head. Not turning over sounds like hydro-lock.
The loud noise..?? Maybe turned over enough, until the piston came up against the coolant in the cylinder, with valves closed. You cannot compress a liquid, but you can bend connecting rods...
/ Engine Locked #3
Sounds about right? Don't use the starter to turn the engine..Check for interferance in revolving, possible bent rod.? Maybe ?
/ Engine Locked #4
Classic symptoms of a blown engine. Probably head gasket. Could also be that the injectors were way out of whack and you burned a hole in the piston. That usually won't result in a lock. Operating at full load with low coolant or a blocked radiator will do just that. Blow a gasket, crack a head, expand pistons from the heat until they friction weld to the cylinder walls.
Sorry. it sounds bleak to me.
/ Engine Locked #5
Ford, you left out using a lot of ether to repeat starting of tractor engine.I saw a Case hammered to pieces inside, Ether bent and destroyed all the internals, big holes in pistons and offset the rods....Not mine...
/ Engine Locked #6
I was cutting hay the 6610 on our farm and the crankshaft just broke for no reason, the tractor stayed running. It broke right in a main bearing, could not tell it was broke by looking.
/ Engine Locked
Thank you all for the comments, they confirm what the tractor mechanic was saying, tractor on the way to the shop.......thanks once again
Takeuchi TB225 (A62177)
Takeuchi TB225...
Screen USA CF35D2 Tri Axle Towable Trommel Screener (A61572)
Screen USA CF35D2...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
KSI Conveyor (A63688)
John Deere Z997R (A60462)
John Deere Z997R...
2016 Kubota L3301 (A62177)
2016 Kubota L3301...
