Engine knock
/ Engine knock #1
v8crazy
Alabama
Farmpro 2024
I have a Farmpro 2420 With a Y385 engine I believe. Yesterday while pulling it into the barn it started knocking. It sounds like it was coming from exhaust at first then After I checked fluids I restarted it for a few seconds and it sounds like front part of engine like number 1 cylinder. It has about 350 hours on it. I am just wondering where to start. Is the oil pan hard to drop I have not crawled under it yet. I will try to post a video later today. Thanks
/ Engine knock #2
V8crazy,
You didn't say how is the oil pressure? (React as it was before)
Do you ever adjust the valves and head retorq? (To be check first)
If ok, then start the engine and loosen and retight the injector line at the injector one after the other. The fuel should skuirt at the tube nut on each one.
Listen for sound change.
Knock stop on one cylinder then resume after tighting the injector Tube?
HOPE NOT.
It happen once on my tractor but stop after restart, fuel knock only.
Jacques
/ Engine knock #4
If the color of the exhaust changed or bubbles in the radiator possible blown head gasket.
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
2004 Peterbilt (A62679)
2004 Peterbilt...
Linx EQ10020RS 20ft Trailer (A65640)
Linx EQ10020RS...
300-gallon Fuel Tank (A66408)
300-gallon Fuel...
2012 Hyundai Sonata (A62679)
2012 Hyundai...
2006 Isuzu NPR Box Truck, VIN # JALB4B16567020383 (A65563)
2006 Isuzu NPR Box...
