Engine for L2250
   / Engine for L2250 #1
scottbennet
I have a L2550 with a bad engine. I inherited it after somebody remove the engine cylinder head and left it off in the rain. It has low compression in the cylinders. Does anyone know where I can get a used engine or a reman unit. Thanks.
   / Engine for L2250 #2
The engine in it is a Kubota D1402-DI-A according to tractordata. Most of the Kubota engines are well supported in the rebuild industry. If you look you should be able to find a data plate with the engine number on it. With luck a local shop should be able to rebuild it for less than a rebuilt engine. Good luck and keep us posted.
   / Engine for L2250 #3
Searched and found this old thread....
I have a L2250 needing a motor or a rebuild.......curious how this one turned out?
Dave
2016 Gravely Pro-Turn 260 60in Zero Turn Mower (A48082)
2016 Gravely...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2020 INTERNATIONAL LONESTAR TANDEM AXLE SLEEPER (A51222)
2020 INTERNATIONAL...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A51039)
Kubota 24in Quick...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
