engine dies when ram moves forward on logsplitter
/ engine dies when ram moves forward on logsplitter #1
oldnfat2
millersburg il
none
Have 16 hp briggs,28 gph pump. whats going on used to work fine.
homemade set up. what the **** went wrong?
/ engine dies when ram moves forward on logsplitter #2
:welcome:
/ engine dies when ram moves forward on logsplitter #3
Sounds like the govner not working right
/ engine dies when ram moves forward on logsplitter #4
Install a hyd pressure gage in a tee in the IN port of the splitter valve and you will probably hae your answer.
Somewhere you are blocking the hyd fluid and the engine will probably stall and quit if the relief valve can not handle the volume of fluid.
Maybe the relief is not working
Could be a malfunction QD, or valve lever in wrong position.
If it only does this with the log splitter , it is probably the QD's.
I'm going to take your advice.Will let eveyrbody know when i find the culprit.
Thanks Gary
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
3pt Hitch Receiver  (A62679)
3pt Hitch Receiver...
C&S FARMS AUCTION - IN LOVING MEMORY OF JACKSON STRICKLAND. (A64277)
C&S FARMS AUCTION...
2017 CATERPILLAR 289D SKID STEER (A65053)
2017 CATERPILLAR...
2022 HAULMARK 14' T/A ENCLOSED TRAILER (A65643)
2022 HAULMARK 14'...
2019 Cub Cadet Ultima ZT 1 50in Zero Turn Mower. (A64557)
2019 Cub Cadet...
