engine dies when ram moves forward on logsplitter
   / engine dies when ram moves forward on logsplitter #1
oldnfat2
millersburg il
none
Have 16 hp briggs,28 gph pump. whats going on used to work fine.
homemade set up. what the **** went wrong?
   / engine dies when ram moves forward on logsplitter #2
:welcome:
   / engine dies when ram moves forward on logsplitter #3
Sounds like the govner not working right
   / engine dies when ram moves forward on logsplitter #4
Install a hyd pressure gage in a tee in the IN port of the splitter valve and you will probably hae your answer.
Somewhere you are blocking the hyd fluid and the engine will probably stall and quit if the relief valve can not handle the volume of fluid.
Maybe the relief is not working
Could be a malfunction QD, or valve lever in wrong position.
If it only does this with the log splitter , it is probably the QD's.
I'm going to take your advice.Will let eveyrbody know when i find the culprit.
Thanks Gary
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2021 FREIGHTLINER...
UNUSED DIGGIT HEAVY DUTY 20'X20' ALL-STEEL CARPORT (A54757)
UNUSED DIGGIT...
2017 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A54607)
2017 FREIGHTLINER...
UNUSED IRANCH SEMI AUTOMATIC QUICK CHANGER (A54757)
UNUSED IRANCH SEMI...
CAT Skid Steer (A50322)
CAT Skid Steer...
