Engine died from too much load, now won't restart
   / Engine died from too much load, now won't restart #1
adegiulio
Red Hook NY
JD 4310
Good afternoon from frosty New York State. I was just outside pushing snow around with my 2003 4310. As I worked myself into a rather large snowbank, I got a little too aggressive in my push and the engine stalled out. It's one of those things that has happened before. Usually, when trying to restart, the engine will run a little rough for a few seconds and then resume smooth operation. Well, this time i started, but immediately died. I repeated the process 4 or 5 more times, with similar lousy results. I should note that I relieved all the pressure on the bucket so as not to force the engine to have to work against that.
I hopped off to give it some time to let any residual pressures or anything dissipate. I went back out but encountered the same results. Any thoughts on what the problem might be? I'm nervous.. :)
Thanks!
   / Engine died from too much load, now won't restart #2
Check the fuse for the fuel shut off solenoid.
   / Engine died from too much load, now won't restart #3
And I'd check that a forward pedal returned to neutral. As well as the gear lever in neutral position.
   / Engine died from too much load, now won't restart #4
I would start with checking that you have fuel in the tank and that your filter isnt gelled up (are you using something like the white power service?)...
Aaron Z
   / Engine died from too much load, now won't restart #5
All of the above but that doesn't sound good. You may have broke a timing chain or gear (depending on what that engine has for a setup. Or some other part that couldn't take the strain of the sudden stop. Perhaps a bent connecting rod or valve stem.
   / Engine died from too much load, now won't restart #6
Since it starts even if it won't stay running most likely some thing simple.
   / Engine died from too much load, now won't restart #7
Can you get it/drag it somewhere warm?
I would be wanting to rule out a cold weather fuel problem before suspecting other things.
Dave M7040
   / Engine died from too much load, now won't restart #8
The OP hasn't checked back in since his 2-28 post, so suspect he's not still interested or has the problem fixed.
Hope he lets us know.
   / Engine died from too much load, now won't restart #9
I would have asked what temperatures he was working in. Probably nothing catastrophic!
   / Engine died from too much load, now won't restart #10
I'd guess that the reason it died originally is the same reason it won't start now. It may have lost power because it ran out of sufficient fuel flow.
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
2013 Big Tex 16GP-20 Gooseneck Trailer (A53117)
2013 Big Tex...
Adams 5T High Clearance Fertilizer Spreader (A53473)
Adams 5T High...
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
