Engine Cuts Out
   / Engine Cuts Out #1
msb1766
Platinum Member
Guilderland, New York
SC2450 Cub Cadet/Yanmar
I have a Craftsman GT-5000 tractor with a 25HP Kohler Pro engine.
The engine will cut out after 20 mins. for mowing, I does not stall out but the rpms drops for a few seconds the runs normal for a few minutes , then it cuts out.
   / Engine Cuts Out #2
I would check the fuel lines and the fuel filter first.. If all of that is good I would start checking the ignition system such as the plug and plug wire makiung sure you don't have a wire shorting out..Hope that helps..
   / Engine Cuts Out #3
Check the vent on the gas cap. If stopped up, will cause a vacuum in the tank and starve the carburetor. Check float, maybe sticking. A carb kit for those engines is about $26.00.
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2018 CATERPILLAR 299D2 XHP SKID STEER (A52705)
2018 CATERPILLAR...
2011 John Deere 120D (A47477)
2011 John Deere...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
Ox Bodies 13.5ft 12-14Yd Dump Box Truck Body (A52377)
Ox Bodies 13.5ft...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
