Engine Cuts Out
   / Engine Cuts Out #1
msb1766
Platinum Member
Guilderland, New York
SC2450 Cub Cadet/Yanmar
I have a Craftsman GT-5000 tractor with a 25HP Kohler Pro engine.
The engine will cut out after 20 mins. for mowing, I does not stall out but the rpms drops for a few seconds the runs normal for a few minutes , then it cuts out.
   / Engine Cuts Out #2
I would check the fuel lines and the fuel filter first.. If all of that is good I would start checking the ignition system such as the plug and plug wire makiung sure you don't have a wire shorting out..Hope that helps..
   / Engine Cuts Out #3
Check the vent on the gas cap. If stopped up, will cause a vacuum in the tank and starve the carburetor. Check float, maybe sticking. A carb kit for those engines is about $26.00.
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
2021 M&J PRESHRED 4000M SHREDDER (A53426)
2021 M&J PRESHRED...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
STORAGE SHELTER KIT (A53843)
STORAGE SHELTER...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
