Engine cuts out, while brake deployed, when getting exiting tractor.
   / Engine cuts out, while brake deployed, when getting exiting tractor. #1
Kevinhazelnut
LL2300 / MT2 25s
Also, I can no longer start the tractor unless seated. This limitation is new and I will contact the dealer, but wondering if others have had this issue and how it was resolved. Thanks!
   / Engine cuts out, while brake deployed, when getting exiting tractor. #2
Have you read the operators manual for this tractor? I don't own an LS therefore no operator's manual but I spect you are witnessing effects of safty devices such as seat sensor to prevent standing while tractor is moving.
   / Engine cuts out, while brake deployed, when getting exiting tractor. #3
Starting usually requires that the gear/range select be in Neutral, Brake pressed, and a butt in the seat. Getting off while running requires Parking brake on and gear/range in Neutral.
   / Engine cuts out, while brake deployed, when getting exiting tractor. #4
Sounds like one of your safety interlock switches has malfunctioned. Possibly your parking brake switch, even though you are applying the brake the switch is not sending the signal to the relay or the relay has failed.
Do you have an wiring schematic for your tractor and a Volt Ohm Meter?
Forgot to say Welcome to TBN, lots of good information here.
   / Engine cuts out, while brake deployed, when getting exiting tractor. #5
If HST the sensor on it is not adjusted correctly or inop. If the tractor thinks one of the pedals is active you get those results.
Earthway Spreader (A57454)
Earthway Spreader...
40' 1 Trip Shipping Container (A59814)
40' 1 Trip...
Heaven Hill Bourbon Barrel (A57454)
Heaven Hill...
10 Ton Scale (A57454)
1999 Mack CH613 Day Cab Truck, VIN # 1M2AA14YXXW101220 (A57453)
1999 Mack CH613...
HAMM H11 PADFOOT ROLLER (A58214)
HAMM H11 PADFOOT...
