Engine cranks sometimes, usually not
/ Engine cranks sometimes, usually not #1
jbeall
Bronze Member
John Deere 2210
Hi All,
I've got a Power House Prowler TF224 (same as a Boxer TF224--both are manufactured by Mertz) mini-skid. It's got a Honda GX670 engine on it.
I'm having electrical issues and am hoping to get a little direction on where to start. When you turn the ignition key, most of the time you just hear a click, the transmission cooler fan comes on, but the engine doesn't crank. But if you keep trying, eventually the engine will crank. It's like the ignition key has to be in the exact perfect position in order for the starter motor to fire.
My initial suspicion is the ignition, especially because it was replaced with a generic ignition that doesn't really fit on the unit. He wound up breaking the plastic housing where the ignition is supposed to sit. But he made it fit :)
I would like to try replacing it with the right ignition, but I'm not sure how to find what the "right" ignition is. I can't find a parts manual, or even an owner's manual, for this unit anywhere.
Any suggestions on where to go at this point?
Thanks!
-Josh
/ Engine cranks sometimes, usually not #2
You could verify that it is a bad ignition switch by using a jumper wire from the + batt terminal to the solenoid terminal.
You could try to install a higher end universal ignition switch or call construction equipment salvage yards to see if you can locate a junked machine with a good switch.
Hi All,
I thought I'd give everyone a quick update--after replacing the ignition switch with the correct one from the manufacturer, the starter cranks right up.
So that issue is taken care of. There are other engine issues I need to look into next... It loses power when it goes under load. I suspect a governor issue but will do some more checking and see what I come up with.
Thanks to everyone for you input and suggestions!
-Josh
2019 HYDREMA MX14 TIER 4 MOBILE EXCAVATOR (A63276)
2019 HYDREMA MX14...
Kubota ZG222 (A60462)
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2005 MACK CXN613 6X4 T/A  DAY CAB TRUCK TRACTOR (A59911)
2005 MACK CXN613...
2018 Kenworth T880 Quad Dump (A62613)
2018 Kenworth T880...
