Engine bogging down and stalling
   / Engine bogging down and stalling #1
dawii
sandra55
My machine has a 4 cylinder kubota engine (bought new/rebuilt motor a few hundred hours ago. Suddenly, it started bogging down and stalling and then chugging and cycling through. It sounds like it’s not getting fuel. (It’s an old Bobcat 7753). Any ideas what things might cause this?
   / Engine bogging down and stalling #2
Have u tried back blowing the fuel line.?
Take the line from the inj pump, loosen the tank cap & using compressed air, back blow the fuel line..till it bubbles in the tank..
Good luck
   / Engine bogging down and stalling #3
Does the fuel gauge work? How full is the fuel tank? The older Bobcats have the tank under the motor with both supply and return lines in rubber bushings on top of the tank. The supply standpipes have been known to deteriorate and fall apart. when that happens it won't pump fuel properly when the level is at or below any damaged spots on that pipe. You might try adding a little more fuel to see if it makes any difference.
   / Engine bogging down and stalling #4
Harry is correct..
So listen to the air/bubbles of the air going back to the tank.. if the fuel is low or the inlet pipe has fallen off, you’ll hear air.. if things are good, you’ll hear bubbles.
   / Engine bogging down and stalling #6
Fuel tank vent plugged?
2022 Club Car Tempo Cart (A55853)
2022 Club Car...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND64FDGH1772 (A54865)
2015 Freightliner...
Kubota LA1055 (A53314)
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A55302)
Greenworks...
2021 KENWORTH T270 24FT BOX TRUCK (A56129)
2021 KENWORTH T270...
