Engine Block Heater ?
   / Engine Block Heater ? #11
I owned a B7500 for a couple years, thought I would need a block heater, but never got around to installing it. I NEVER had a problem starting the B7500. It was stored in a machine shed up here in Wisconsin. Several days below zero...etc..
   / Engine Block Heater ? #12
BILLMAN,
I would definitely recommend the Kubota block heater. It does make a BIG difference in cold weather. My BX2200 will start when it's cold but it is much smoother when the heater is used and engine warm up time is reduced practically to nothing. The temp gauge starts climbing almost immediately. You should still let it run for a few minutes to warm the hydraulic fluid some before heavy use. They claim it will also give your diesel longevity. For the cost of these diesels it is well worth the price of a block heater in cold climates to get all you can get from them. Once they are installed you never know they are there until you need to plug them in. Wouldn't be without one on a diesel. /w3tcompact/icons/smile.gif
2018 CATERPILLAR 12M3 MOTORGRADER (A52709)
2018 CATERPILLAR...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1EF7EKF89312 (A57453)
2014 Ford F-150...
2019 Chevrolet 1500 Silverado Crew Cab Pickup Truck (A55973)
2019 Chevrolet...
2017 FORD F-550 SERVICE TRUCK (A58214)
2017 FORD F-550...
2018 Ford Explorer AWD SUV (A56859)
2018 Ford Explorer...
2017 John Deere 35G Mini Excavator (A55973)
2017 John Deere...
