Engine Balancer????
/ Engine Balancer???? #1
sf876
Troy, SC
M7030, L2250
I just tore down my M7030 with a V4000-3a Kubota engine. I had 3 busted pistons. My question is that in the crankcase there is a ??? anti vibration device??? or some kind of ""balancer"" in front of the oil pump... when I replace this ,,,how do I know that I have it timed correctly, and what is it's proper name??? Thanks in advance...:confused:
/ Engine Balancer???? #2
Harmonic balancer.
It is inside a open box inside the crackcase, with 2 balance pendulum counter weights on each side that swing on a gear assembly. not sure how to replace it.
It's not your everyday harmonic balancer...
Discovered that it is just called a "balancer" and when I went to put it in there is only one way that it could go,,so it was simple ...thanks for the looks and responses..
