engin dont start and pto not turn on kubota m7950dt
   / engin dont start and pto not turn on kubota m7950dt #1
BIdU
kubota/m7950mt
,hello to all my problem no; 1 my pto no longer wants to engage ... the gears gray when I engage the activation lever .. I have tried several speed configurations (A, B, C, D) ratio selector . nothing works... i tried to slow down the rpm of the engine by choking a little with the choke which is near the brake pedal but the engine stopped and since then it doesn't start anymore... i managed to start it by putting ether in the air filter and goes out immediately. I followed the pin which is used to activate the choke and it seems to activate a kind of switch behind the injection pump as well as a lever in front of it. how to reset this pump because just by pushing the pin it seems that the device behind the pump is not in its place,,
in red circle the connect to this but my trouble it's behind the pump the switch is connect with the same actuator...
   / engin dont start and pto not turn on kubota m7950dt #4
From the description of your troubles I think it's time to arrange an appointment with the dealer or a mechanic. In any case I would not recommend ether. Its use can permanently damage an engine and require overhaul.
   / engin dont start and pto not turn on kubota m7950dt #5
On your tractor, are you suppose to use the clutch when engaging the pto? If do you use it? Could the linkage need adjusting?
2023 G Bar K Skirted Hauler Bed (A53472)
2023 G Bar K...
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
2006 TerraGator 8104 (A53472)
2006 TerraGator...
UNUSED FUTURE FT13J EXCAVATOR (A51247)
UNUSED FUTURE...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
