Engaging blades... what throttle do you use?
   / Engaging blades... what throttle do you use? #1
kbuicker
Texas
Kubota Z724XKW
Hey fellas, I used to stick to the theory, when you engage the blades, slow the throttle so your clutch has a better chance of engaging the blades.... but with my newer mower, it seems more of a rough engagement when I slow the throttle and engage the blades. It's almost like it wants a faster throttle engagement?
What do you do? Either way, there's still that nasty 'screeeetch' when engaged.. hate that.
   / Engaging blades... what throttle do you use? #2
I have always throttled down prior to blade engagement. Most manuals mention to do that. Not sure if it really makes a difference or not.
   / Engaging blades... what throttle do you use? #3
Throttle down.
That's a gas engine right? With some (cold) gas engines, you need to give it a quick flip of choke at the same time you're engaging blades so engine has the torque to get them spinning.
   / Engaging blades... what throttle do you use? #4
My Hustler ZT mower wants about 1/4-1/3 throttle. It seems like at idle the clutch slips for a bit, but raising the revs as the manual states works better. I think the clutch may have centrifugal weights to help engagement. The higher speed will help it engage better.
That said, I would not engage the blades at anything higher than 1/3 throttle...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
2020 Polaris Ranger 1000 4x4 Utility Cart (A51691)
2020 Polaris...
2021 John Deere 331G Track Loader (A53342)
2021 John Deere...
BY VALLEY INDUSTRIES 60 R22 823 LOT NUMBER 236 (A53084)
BY VALLEY...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2018 INTERNATIONAL...
KUBOTA MX4700D TRACTOR (A51247)
KUBOTA MX4700D...
