Engaging blades... what throttle do you use?
   / Engaging blades... what throttle do you use? #1
kbuicker
Texas
Kubota Z724XKW
Hey fellas, I used to stick to the theory, when you engage the blades, slow the throttle so your clutch has a better chance of engaging the blades.... but with my newer mower, it seems more of a rough engagement when I slow the throttle and engage the blades. It's almost like it wants a faster throttle engagement?
What do you do? Either way, there's still that nasty 'screeeetch' when engaged.. hate that.
   / Engaging blades... what throttle do you use? #2
I have always throttled down prior to blade engagement. Most manuals mention to do that. Not sure if it really makes a difference or not.
   / Engaging blades... what throttle do you use? #3
Throttle down.
That's a gas engine right? With some (cold) gas engines, you need to give it a quick flip of choke at the same time you're engaging blades so engine has the torque to get them spinning.
   / Engaging blades... what throttle do you use? #4
My Hustler ZT mower wants about 1/4-1/3 throttle. It seems like at idle the clutch slips for a bit, but raising the revs as the manual states works better. I think the clutch may have centrifugal weights to help engagement. The higher speed will help it engage better.
That said, I would not engage the blades at anything higher than 1/3 throttle...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
2024 JOHN DEERE 3039R LOT NUMBER 165 (A53084)
2024 JOHN DEERE...
2012 JOHN DEERE 410K BACKHOE (A51406)
2012 JOHN DEERE...
2009 Caterpillar 279C High Flow Compact Track Loader Skid Steer (A51691)
2009 Caterpillar...
WOODS DS8.50 LOT NUMBER 247 (A53084)
WOODS DS8.50 LOT...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
