Engagement of mowing blades on Cub Cadet Z-44
   / Engagement of mowing blades on Cub Cadet Z-44 #1
Steve Rose
Mowing Blade is not engaging when the right lap bar is pushed forward. Is this controlled by the Normally Closed Safety Switch? Or what should I check first?
   / Engagement of mowing blades on Cub Cadet Z-44 #2
Steve, we need more info. Under what conditions is your PTO working? With the reverse safety switches in stock form, the PTO should only cut off when both lap bars are pulled back. Once one bar is moved forward the PTO should turn back on. Basically if both switches are pressed (opening both), power is cut to the PTO.
Joel
294 (A52706)
294 (A52706)
2012 FORD F-250 SUPER DUTY (A58214)
2012 FORD F-250...
2 Warehouse Forks (A55787)
2 Warehouse Forks...
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A55315)
1995 Ford F-250...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
2017 JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
2017 JOHN DEERE...
