Engagement of mowing blades on Cub Cadet Z-44
   / Engagement of mowing blades on Cub Cadet Z-44 #1
Steve Rose
Mowing Blade is not engaging when the right lap bar is pushed forward. Is this controlled by the Normally Closed Safety Switch? Or what should I check first?
   / Engagement of mowing blades on Cub Cadet Z-44 #2
Steve, we need more info. Under what conditions is your PTO working? With the reverse safety switches in stock form, the PTO should only cut off when both lap bars are pulled back. Once one bar is moved forward the PTO should turn back on. Basically if both switches are pressed (opening both), power is cut to the PTO.
Joel
New Holland 499 Hydra - Swing Mower Conditioner (A50514)
New Holland 499...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
Best 30' Grain Drill (A50514)
Best 30' Grain...
2003 Club Car Electric Cart (A50324)
2003 Club Car...
10' Feed Bunk (A50515)
