Engage PTO at high idle or full throttle?
   / Engage PTO at high idle or full throttle? #11
For me - it depends. On the tractor - I can "feather" the engagement. So - I fully engage at idle( Wallenstein chipper). The riding lawn mower has an electric engagement system. So it has to be at high idle or the engine might stall.
   / Engage PTO at high idle or full throttle? #12
I also engage at about 1/3 throttle. I also disengage at just above idle to save wear on the PTO brake.
   / Engage PTO at high idle or full throttle? #13
On my X540 I engage the deck just above idle by applying the choke about halfway first. This keeps the engine from stalling and prevents the jerk and belts squealing. Prior to this had to be close to full throttle or the engine would stall.
^This.
Pretty much the same method I use. At idle I give the choke lever a blip at the exact same time I engage pto switch when motor rpms would normally take a dip (and stall) from the load shock.
It's bad enough they started putting electric pto's on riding mower tractors , but on actual utility, CUT's and SCUT's is ridiculous. I would never buy a tractor with that I planned on running implements with that had an electric pto switch.
   / Engage PTO at high idle or full throttle? #14
I guess they are designed to handle the jolt, but it would be nice if the
electric clutches would feather in slightly first. I hate the driveline
shock, even at idle
   / Engage PTO at high idle or full throttle? #15
I was just curious because some folks claim you should engage at full throttle. Thanks.
Some folks shouldn't operate equipment & I'm not referring to you. Low engine speed pto clutch engagement will increase clutch longevity!
   / Engage PTO at high idle or full throttle? #16
Tx Jim - Boy, ain't that the truth. Some could break my 140# anvil with a feather.
John Deere 710G Extendahoe Backhoe Loader (A44571)
John Deere 710G...
2000 MACK CH (A45046)
2024 EGN EG360T Ride-On Skid Steer (A42203)
2024 EGN EG360T...
TOYOTA SHOP LIFT(INOPERABLE) (A45333)
TOYOTA SHOP...
2014 WESTERN STAR 4900 SF (A45333)
2014 WESTERN STAR...
HYDRAULIC SQUEEZE OFF (A45333)
HYDRAULIC SQUEEZE...
