Engage PTO at high idle or full throttle?
   / Engage PTO at high idle or full throttle? #1
Vigilant
Bronze Member
On an X500, will I reduce wear and tear on the PTO clutch if I engage it at high idle instead of full throttle, or is full throttle better?
Thanks in advance.
   / Engage PTO at high idle or full throttle? #2
I only ever engage an implement at just enough RPM not to stall the engine, then increase.
Same here. I was just curious because some folks claim you should engage at full throttle. That's why I posed the question. Thanks.
That's what I thought. Thanks.
   / Engage PTO at high idle or full throttle? #7
Kind of the same with a manual car, unless you are into drag racing and breaking things.
   / Engage PTO at high idle or full throttle? #8
On my X540 I engage the deck just above idle by applying the choke about halfway first. This keeps the engine from stalling and prevents the jerk and belts squealing. Prior to this had to be close to full throttle or the engine would stall.
Good idea. I'll give that a try. Thanks.
2014 Infiniti QX70 SUV (A44572)
2014 Infiniti QX70...
2010 UTILITY 53X102 DRY VAN TRAILER (A43004)
2010 UTILITY...
2013 KENWORTH T800 MID-ROOF SLEEPER (A45333)
2013 KENWORTH T800...
2013 ALLMAND LIGHT TOWER (A45046)
2013 ALLMAND LIGHT...
Deere 330G (A44501)
Deere 330G (A44501)
Club Car Electric Golf Cart (A44502)
Club Car Electric...
