Enclosed trailer repair
   / Enclosed trailer repair #1
ticolawnllc
Bronze Member
Bob Cat CT120
A young lady ran a red light and wrecked my truck and trailer. Any help would be appreciated.
My app. Keeps crashing so I'm posting one pic at a time
This is from the inside
   / Enclosed trailer repair #4
Assuming you want to tackle this yourself? If so, you're going to need some tools. Bringing it to somebody that does body repair might be the best way, though. Maybe somebody that does it in their home shop for cash?
The idea is for me to do it in the winter when I have plenty of time. I don't think it would be worth it to pay someone that's any good to do it. That bing said if any one is going to do crummy work its going to be me lol
   / Enclosed trailer repair #6
I have experience doing this.
It's not difficult. But, there is a learning curve to riveting. And, you will need some special tools.
Keep in mind, it's also a two man job.
Finding that corner flashing is what worries me most.
Is it just chrome sheet metal bent over or if it's shaped in any way.
   / Enclosed trailer repair #8
If she ran a red light her insurance should pay for the truck and the trailer. Let somebody else fix it. If she doesn't have insurance, take her to court for damages.
   / Enclosed trailer repair #9
I don't know about this manufacturer, but when I have bought front corners, they were already formed.
   / Enclosed trailer repair #10
Under the metal is often a flimsy 2" wood framing so that's the easy part.
If metal 'studs' cut to make them into a straight shape and double up with 3/4" plywood and again use screws to fasten the metal studs to the wood.
The corner metal you should be able to purchase locally from a trailer yard and if lucky even get a used section.
If you don't want to get involved with rivets you can always back any seams with wood and use screws and if you do so use strips of plywood for the screws to have a better grip.
Torn trailer 'skins' can be externally patched (not all that pretty, but functional) using pop rivets and sealant.
It can be done, takes time and patience.
30pc 3ft. x 8ft. Red Polycarbonate panels (A53424)
30pc 3ft. x 8ft...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55301)
GOODYEAR SET OF...
LEEBOY PF1510B ASPHALT PAVER (A51406)
LEEBOY PF1510B...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2003 CATERPILLAR D6R XW HI-TRACK CRAWLER DOZER (A51406)
2003 CATERPILLAR...
