Enamel hardener and paint safety...
   / Enamel hardener and paint safety... #22
Harry C,
You don't work with iso's in an aerosol spray form do you? The danger goes up as the particle size goes down. A gallon bucket sized particle is not as dangerous as a 35micron diameter particle. You put a gallon can of iso's in a room of people for 15 min and maybe a few get sick. You spray that same gallon into the same room with a paint gun and they all get sick or worse. Probably much worse....
jb
   / Enamel hardener and paint safety... #23
You can get a 3m respirator for under 30 bucks at paint and body supply stores
Or oriellys
   / Enamel hardener and paint safety... #24
sixdogs said:
I like to paint a used implement when I buy it and have been thinking of using the Valspar "Enamel Hardener" from TSC. I am not sure if it is safe or not even though I have a good paint respirator.
The ingredients listed in the can are "Aliphatic Polyisocyanate and Isophorone Diisocyanate" along with Naptha and N-Butyl Acetate.
The can mentions you MUST use a good paint respirator but you MAY also use a supplied-air system.
Can anyone help understanding this? I paint outside.
I use the stuff...WITHOUT a mask...but I ALWAYS am spraying outside...:D. No way Id use it in a confined space ( indoors) without a proper mack.
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A55973)
2020 Ford F-250...
Terms & Conditions of (Buying through EquipmentDealz Auction) Final (A59213)
Terms & Conditions...
John Deere 5055E (A53317)
John Deere 5055E...
2019 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2019 Freightliner...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
Stanley Hydraulic power pack (A56435)
Stanley Hydraulic...
