Emergency Starting TC30 with Jumpers???
   / Emergency Starting TC30 with Jumpers??? #11
And make sure the key is on when you are jumping it
Think I figured out what's going on. The starter is freezing up in the extreme cold. A buddy who works on heavy equipment says their loaders freeze up when snow dust gets into the starters. I put a heat lamp on it and it started right up. Thank god. I'll leave the heater on it tonight and hope it starts tomorrow!
   / Emergency Starting TC30 with Jumpers??? #13
Did that make it start with the key or with the jumper?
If you do have a safety that it is bad, it is unlikely that jumping the starter will help unless someone is also sitting on the seat. IE: IF the PTO is engaged it will lock out the start function. IF the PTO is engaged and no one on the seat, it will kill the fuel. So not only is someone on the seat a good idea, it is also required if indeed a PTO safety is bad.
2017 Makita HM1307CB 35lb Demolition Hammer (A55973)
2017 Makita...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
Year: 2014 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: 132,994 Plate: Body Type... (A56859)
Year: 2014 Make...
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
