Emergency flashers
   / Emergency flashers #1
Nelson Farms
Mississippi
John Deere 5520 Massey Ferg 383 and 1035 compact
Having problems with my emergency flashers on my John Deere 5520 cab. The signal lights work fine but the flashers doesn't work.
   / Emergency flashers #2
Have you checked for a blown fuse?? Possible faulty warning light switch.
I checked all the fuses and relays I noticed that only my regular beams on lights work so it may be the switch.
   / Emergency flashers #5
Different tractor, but on my 2305, the problem ended up being a blown diode, located in the wiring harness behind the instrument panel cowling.
   / Emergency flashers #7
Does that tractor use a mechanical blinker module? If so, remove it and either check voltages on or short across the pins on that connector. Sometimes just flicking it with your finger will get one unstuck.
   / Emergency flashers #8
Thanks for the link Chipsndust! Mine stop working this summer.
PETERBILT 388 CAB (A53843)
PETERBILT 388 CAB...
2025 AGT 750 (A50123)
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
2013 Ford F-250 Pickup Truck (A51692)
2013 Ford F-250...
2008 Honda Pilot SUV (A53117)
2008 Honda Pilot...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
