Emax 22 RPM gauge inop
   / Emax 22 RPM gauge inop #1
mcleod9
Mahindra emax 22s
My rpm gauge stopped working. All the other gauges work fine. Any ideas? I'm trying to figure out how to get the dash off to check the gauge wiring.
   / Emax 22 RPM gauge inop #2
Mine did the same thing. Try squeezing the orange wire connection to the alternator. My dealer said this is a relatively common problem, and it usually turns out to just be the loose wire. It fixed my problem.
   / Emax 22 RPM gauge inop #3
This is the connection that was loose on mine.
No luck. I even seperated the wire connection you showed. Everything was good there. I broke down and removed the steering wheel and the instrument console. No sign off any damage to the wiring harness. I unplugged the two connectors on the rear of the panel, sprayed both with contact cleaner. Didn't help. I'm thinking the gauge itself may be bad. Only 55 hours seems a little fast, though. thanks
MISC, 3 MAN HUNTING BLIND, FISHING POLES (A51244)
MISC, 3 MAN...
2022 Iron Craft 10' 3pt. Rotary Mower (A50774)
2022 Iron Craft...
2018 FORD F550 XL SINGLE CAB SERVICE TRUCK (A51243)
2018 FORD F550 XL...
UNUSED KIVEL SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED KIVEL SKID...
Club Car Electric Utility Cart (A51694)
Club Car Electric...
(INOP) KUBOTA RTV1140 CREW CAB ATV (A51243)
(INOP) KUBOTA...
