eMax 22 / 25 Hints & Tricks
   / eMax 22 / 25 Hints & Tricks #51
On my Daedong, the glow plug relay is on the right side closer to the firewall under the fuse panel. There are two things that look like relays there. the back one(firewall side) is the glow plug relay. The one forward of it is the ECM. I had to replace both as the plug relay wires rubbed on a bolt or bracket(can't remember) and shorted out. Was having trouble with the plugs not operating correctly and eventually took out the ECM.
I have 2 relays on the right side while sitting on the tractor both of which I tested and they are good. Mine are above a fuse box.
But there are also 2 more relays on the right side standing in front of the tractor above another type of fuse box (4 or 5) I believe are the main fuses.
Wish I had a good service manual that wasn't $50.00 and written in good english. Owners manual is crap too.
   / eMax 22 / 25 Hints & Tricks #52
Hmmm, well I looked at mine again tonight and I only have the two relays on the right side. Mine is a 2016/17 model with the Daedong. I know Mitsubishi was used also somewhere around that time.....
   / eMax 22 / 25 Hints & Tricks #53
Dealer looked at it said there was air in the fuel line. Got it started. Then they tried starting again day after, would not start. Then they found a blown fuse. Starts now.
That is the same thing that happened to me.
Strange, hopefully this behavior doesn't repeat or I will looking for short.
   / eMax 22 / 25 Hints & Tricks #54
Well, I guess that's fairly good news!
   / eMax 22 / 25 Hints & Tricks #55
I'm new here. Emax 22 2016 no start problem but while I'm here I'll tell you a little hint that I found. Fuel shut off lever on the fuel filter is very poorly connected to the valve it's moves. If you do not push down on the select lever it can actually turn without turning the valve resulting in a no fuel flow situation anybody else seen this?
   / eMax 22 / 25 Hints & Tricks #56
Hi Anthony. Let's look at "no start". Turning the key, do ya get any lights, dash icons, clicks, engine crank, or is it plain dead? Joe H.
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
Unused 78" Bucket Attachment (A55272)
Unused 78" Bucket...
2010 CHEVY SILVERADO 3500 HD PICK UP TRUCK (A59575)
2010 CHEVY...
2019 C.GALLEGOS PNEUMATIC TRAILER (A58214)
2019 C.GALLEGOS...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
Giyi 72" Mulcher (A57149)
Giyi 72" Mulcher...
