eMax 20 oil volumes in the book: wrong?
   / eMax 20 oil volumes in the book: wrong? #1
Sgt Slag
2019 Mahindra eMax 20S
Pulled both drain plugs on the front wheels, last night, and the filler cap; turned the wheels, repeatedly, to push out more used oil, from the system. Manual specifies 2.5 Liters of oil, but I put 2 Liters in, with 1/2 Liter running on the floor (filled the funnel too fast, it overflowed the fill hole...), and I still had too much fluid in it (rotated the wheels, again, to circulate the oil; will check the level today, to be sure there is enough oil in the system). Ended up sucking out new oil using my shop-vac with an aquarium hose, per a YouTube video using an old 32 oz. soda bottle to contain it, within the vacuum -- worked superbly). Preparing to change the main HTF fluid, tonight, along with the filter, and cleaning the screen. Book specified 3+ gallons of oil. Planning to add 2 gallons, watching the sight glass, carefully, as I add more.
Any other eMax 20 owners experienced this issue with the book listing too much oil in the change process? I had the front end on jack stands, up six inches higher than the ground, for better access. I doubt that prevented more than one liter of oil from draining... Cheers!
   / eMax 20 oil volumes in the book: wrong? #2
never rely on fill amounts to be exact. they dont specify if its new fill or refill amounts. there is a difference.
   / eMax 20 oil volumes in the book: wrong? #3
How much oil drained out? On my tractor there are plugs at the top in addition to the drain plugs, if these are not removed when filling then an air lock prevents the flow of oil after a point.
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
Unverferth Model 1225 Double Rolling basket (A52349)
Unverferth Model...
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
(4) Radial ST 225/75 R15 Tires (A50121)
(4) Radial ST...
New Holland T5060 Tractor (RIDE AND DRIVE) (A50774)
New Holland T5060...
John Deere 6115M (A50120)
John Deere 6115M...
