Electronic Tachometer for Kioti LK3054?
   / Electronic Tachometer for Kioti LK3054? #1
DennisZ
Santa Ynez, Ca
Kioti LK3054
Sorry, I answered my own question. The LK3054 is a diesel with no distributor like a gasoline engine. Nothing that I know of to hook an electronic tach to.......
   / Electronic Tachometer for Kioti LK3054? #2
G'day if you look up tiny tach they are a small elec tach that picks up off an injector line with a wire simply wrapped around it.
Jon
Thank you, Jon. I will look them up. Appreciate the input. Have a great day!
   / Electronic Tachometer for Kioti LK3054? #4
Dennis,
Are you having tach problems? If so did you get the Electrical one? Did it work? My tach isn't working and I'm not looking forward to forking out $380 for a new cluster.
I didn't buy the new tach. The problem with my factory tach was that the end of the tach cable that plugs into the instrument in the dash hogged out the receiver that it slips into. So, it wouldn't spin the tach properly. I fixed it by putting JB Weld into the receiver in the instrument. Then I put some grease on the end of the tach cable and slipped it into place. I let it dry overnight and then the tach worked fine. I will say that the factory setup for the tack is crappy. The cable has to be tightened just right at the instrument for it to work - otherwise it will over spin the tack needle and maybe even break it off against the stop in the gauge - like it did mine. I fixed that by painting a toothpick bright red and then super glued it to the broken needle in the gauge. It all works fine now. However, I am glad to hear about the electronic tach. If I have any more problems I'll give that a try. Hope this helps.......
Miva Hydraulic Auger, Grapple, & Bucket (A50121)
Miva Hydraulic...
NEW LandHero Mini Stand up Skid Steer (A53002)
NEW LandHero Mini...
2015 Crane Carrier Co. Low Entry (LE2/LD2/LW2/LT2/ST2/SD2) Truck (A51692)
2015 Crane Carrier...
2007 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52577)
2007 PETERBILT 387...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
