Electronic Ignition
/ Electronic Ignition #1
Paul N
Buffalo, MN
AC C, AC 170 gas, AC 180 diesel, Agco Allis 8630 FWA diesel, Farmall H, Farmall M
I was having problems with a broken spring on the ignition points on my Farmall H. A new set of points would last just over a year, and then the spring would break. I was told that the rotor was worn to the point where it wobbled, causing excessive spring movement. Does this make sense? He also said it痴 at least a $300 fix.
I then switched back to a magneto. Starts good when cold, but won稚 start when it痴 hot. I got tired of fiddling with it and went back to the battery ignition.
This time I put a Pertronix electronic ignition system in it. What a huge difference it made! Now it will start cold without choke, hot starts, no problem. When I shift into road gear, no sputtering. It runs almost like a new tractor. For $87.50, I wish I had done that years ago.
/ Electronic Ignition #2
likely the dizzy had worn busings. they cause eratic points gaps.
2018 DRAGON  130BBL VACUUM TRAILER (A65643)
2018 DRAGON...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
Exmark C2-96 (A64127)
NEW 2025 Trailer by Premiere Single Axle 12' Tilt  (A62679)
NEW 2025 Trailer...
