Electronic Ignition for Satoh 650G?
   / Electronic Ignition for Satoh 650G? #1
NCShelton
Monroe, LA
Yanmar YM2000
Does anyone know if Pertronics makes an electronic "breaker point and condenser replacement" for the Satoh 650G? Or, any other manufacturer? Please give mfr & model number if you know it. Also as the exisiting coil may need to be replaced, the model number of a coil matching the electronic ignition.
I recently installed the Pertronic electronic ingnition & coil in a 64 Ford F100, 292 V-8, which resulted in so much improvement in performance that I now want to do it to my Satoh.
Thanks in advance for any help.
Norwood Shelton
Monroe, LA
   / Electronic Ignition for Satoh 650G? #2
Pertronix's catalog doesn't list anything directly for a Satoh. However, the distributor may be able to be cross referenced. I seem to remember reading somewhere that the Mazda engine was used in a forklift, too and that may be useful. I too am interested in adding this to my 650g so if you come across anything please post and I'll do the same.
I finally found a source of the Pertronix electronic ignition for the Satoh S650G.
It is Genesse Products,
http://www.geneseeproducts.com/
The part # is MA-141.
It works!
   / Electronic Ignition for Satoh 650G? #4
That's great, I appreciate you passing the info on. How much of a difference does it make? How much was it.
The kit was 89.95. I did not need the coil. Installation was easy. Instructions were in the box. Runs good.
ns
   / Electronic Ignition for Satoh 650G? #6
Thanks for the tip. I blew my points out again. Instead of going through that again I ordered the kit from Genese. I had to cut my wires and butt-splice them because the ring terminals wouldn't fit through the grommet hole. Maybe took 15 minutes.Would take about 5 the next time, 2 if I didn't have to wire the ballast resistor.
I never asked because I was a little leery of this and tried to go low budget because I try to keep expenses down. If genese had the flamethrower coil as the coil in their package I would have ordered it in hindsight. I had a coil with a lifetime warranty from a parts store. But the flame thrower has a built in resistor and extra power the more I read about it.
The man at Genese was very nice and I would recommend them again. Although I did find it a little cheaper on the web.
By the way, after I installed it I turned the key to start it and it started in like half a second. So quick it startled me. I was expecting to have to re time it, so I was very surprised that it is actually a perfect replacement to the factory points in every way.
All in all I'm very pleased and am glad you shared your post.
Scott
/forums/images/graemlins/laugh.gif
   / Electronic Ignition for Satoh 650G? #7
I talked to somebody at genesee and they told me they don't make an ignition for that distrubuter. How did you find out yours would work?
   / Electronic Ignition for Satoh 650G? #8
I simply called them. I called twice and both times they knew exactly which one they were speaking of. I don't know why he told you that. I'd call and ask again.
Scott
2006 John Deere HPX Gator 4x4 Utility Cart (A50322)
2006 John Deere...
2017 Isuzu NPR Crew Cab 14FT Landscape Dump Truck (A50323)
2017 Isuzu NPR...
2017 Jaguar F-Pace SUV (A50324)
2017 Jaguar F-Pace...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2008 Ford E-350 Versalift Vantel29N 29ft Bucket Van (A50323)
2008 Ford E-350...
