Electronic ignition for Kohler Magnum on Troybilt
   / Electronic ignition for Kohler Magnum on Troybilt #1
quintr
I have an old Troybilt Horse tiller with 8hp Kohler Magnum. Is there an electronic ignition I can retrofit to this? If so, source? Thanks
   / Electronic ignition for Kohler Magnum on Troybilt #2
I don't know if there is an electronic system, but I am curious as to why you want to get rid of the points? I personally like points systems on the old Kohlers. it's easy to get at and set, and cheap to replace.
   / Electronic ignition for Kohler Magnum on Troybilt #3
If I'm not mistaken the Magnum 8 has a points free magneto type "electronic" ignition. I'm pretty sure this was the designation they gave it when it replaced the points ignition K181. As far as a battery powered capacitor discharge type ignition for them, I've never seen one myself but I think there are some out there that the puller guys use for the K singles, but I think the system is timed by the points on the K's, so they wouldn't work on a Magnum.
-Fordlords-
2014 BOMAG BW 213 DH-4 (A52472)
2014 BOMAG BW 213...
NPK H2XA Skidloader Breaker (A50774)
NPK H2XA...
8ft x 6ft Container with Side Door (A51573)
8ft x 6ft...
2002 Sterling M7500 Acterra Lift-All LA04C51 51ft Insulated Forestry Chipper Bucket Truck (A50323)
2002 Sterling...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A50322)
2017 Kawasaki Mule...
2012 Ram 4500 Chassis Vesralift 29ft Bucket Truck (A50323)
2012 Ram 4500...
