Electrical System Light on a GF1800
   / Electrical System Light on a GF1800 #1
arcoladev
Stillwater, MN
Kubota L39, ZD21, Land Pride Stump Grinder
I have a GF1800 mower with about 450 hours on it. Recently the electrical light came on and continues to stay lit. No noticeable problems with the engine idling or running under power (including the grass catcher).
The manual says little about the light in troubleshooting....can any of you suggest a cause or some diagnostics to start with? The battery is relatively new (1 year old)
   / Electrical System Light on a GF1800 #2
I had a similar problem except my lights stopped working and all the fuses were OK. The tractor started and ran. I don't know if your starter switch controls the lights on your tractor, but mine does and it was faulty.
I took a volt meter to check for current from the switch to the lights and there was none. In your case you may have a loose wire that touches so that the switch is by-passed, instead of running through it. Could be an easy fix.
2007 WESTERN STAR 4900 (A52472)
2007 WESTERN STAR...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
10' Poly Feed Trough (A50515)
10' Poly Feed...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
2014 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A50323)
2014 GMC Sierra...
UNUSED TOPCAT QUICK ATTACH HYD 4N1 72"COMBO BUCKET (A51244)
UNUSED TOPCAT...
