Electrical Question
/ Electrical Question #1
FarmTracRay
Wabash valley, Indiana
Farmtrac 300dtc
Have been in the shadows here for some time, my first post/question. Lot of knowledge here. I "should" have a pole barn put up this week, had to move a building built on skids to make room for it. Had power to shed (direct buried 12/3, 100' for 110 volt) for lights. End of wire about 10 feet from new building. Can I safely splice on to it? Power will be for lights, battery charger, maybe/rarely a very small tankless compressor. I know the wire is a little lite but I swear it will be mostly for lighting. New pole barn (24X32X8) will just be to store the toys in. Have a garage for maint, etc.
P.S. We live on an acre, year ago, elderly neighbor lady stopped by and said she was selling and moving to town. Told her we would like to buy 2 acres here beside the house, she said fine but we better be doing it. I sent a letter with proposal (6K for little holler and a hillside that slopes towards our house, we would pay more), she said her son would deal with us (I bought a tractor FarmTrac300, planned on buying mower and tiller later. I called her son who said he would get with us. Not a word since and I am not bothering him again. Now I got a tractor and the most I have done with it is spread and level the 44 tons of road pack for the floor in new building. BUT that was a lot of fun... So anyway I put the cart before the horse buying the tractor, but I'm keeping it and tired of it setting in yard... Thats how I come about the tractor and the small pole barn.
/ Electrical Question #2
Splice kits are available for 12GA UG cable. These kits will give you all the material and instructions for safely making the splice. Kits should be available at a large hardware store. I have seen them at Menard's, but I never looked so I don't know if the orange box has them. I agree with you that #12 is light for 100' but for lights and a battery charger you will be OK. Compressor may be a bit too much but it should work. Use compact fluorescent bulbs to reduce the current draw.
/ Electrical Question #3
if you are going to splice and leave the splice underground be sure to note exactly where the splice is for future reference.
/ Electrical Question #4
At 100' what's another 10'? There are several splice kits for 12 gauge UF. One type for sure is available at big box stores. Gardner-Bender makes one with everything you need to do it. Another alternative is a 3M Splice Kit, which are a PITA and messy.
/ Electrical Question #5
If you're doing a concrete floor, put in an extra large (1.5") conduit with a sweep so you can up the service later should you decide. Building uses have a way of changing as time passes. :)
/ Electrical Question #6
You should really bring it up into a sub panel so you can have a breaker or 2 inside the building. Better to split your lights from your outlets and put your compressor in 1 breaker all its own. That way when you trip something out it trips at the sub panel and not at the source. That stuff is cheep and all at Home Depot. You can even sit at a table and look over the wiring layout in 1 of there how to books
/ Electrical Question #7
You didn't say how you ran the wire. Is it in a trench and is the trench still open? I'm also wondering why you ran 12/3? Why not 12/2?
If so, it won't cost you very much to buy a 250 foll of 10/2 and then use the 12/3 in the barn for you lights and outlets.
You also didn't say what size breaker your pulling the power off of, but I'm guessing it's in the 20 amp range. Anything less would be pretty useless.
You can put a small breakerbox in the shed and split your lines into a 15 for outlets and a ten for the lights. A few lights will only pull a couple of amps, so it's no something you need to worry about having two breakers that total more than your supply line.
If you have more power coming in, than that changes everything.
We really need more details.
If your determined to splice it, than there's plenty of kits that you can use, but for what you'll pay for the kit, and possible future issues, it really would be cheaper to just get the right wire for your needs.
Eddie
/ Electrical Question #8
To be honest Eddy is right, the correct way to do this would be to pull heavier 10/2 wire from your feed to a sub panel. Ground your sub panel and split your feeds. What will work is not always the best way to do something. If you overload the circuit that wire will get pretty warm and it sound like it could get pretty old going back and forth to the source to reset the breaker.
That is a good size building too, your going to regret not giving it a good power feed. If it were I and I don’t know what you have for a service at the source. If you have a 200 amp services run 220 to your sub panel and split into 2 110 legs and then you will have power to run just about anything you want. Even a welder. Power tools at start up put a good draw on a circuit but that is me.
/ Electrical Question #9
If you want to run 220V, you will need to pull a 10/3 line, not a 10/2 as you will need 2 hots, 1 neutral + 1 ground. If all you want to run is 120V, the 10/2 will be sufficient.
Remember the load on a 10/x wire is only 30A, if the distances get longer, that drops to 20A, you will have to check the length restrictions depending on your length requirements.
If you need more than 30A, a bigger wire is required. Only you know what you will need now or in the future. Considering the work involved in putting the wire in the ground, the cost of the wire is minimal compared to the labor to redo the job later.
Just my 2 cents.
Derek
/ Electrical Question #10
Derek
not entirely true. on a 220v system there is no "neutral" addtionaly neutral IS ground. (ie if you look in the pannel it SHOULD have the neutral tied to the ground side)
so you can set a new sub pannel, set a new ground rod for the pannel (per code) and your good to go.
/ Electrical Question #11
I would hope that you are trying to say that he would still need 10/3 with or without a grounding conductor. The grounded conductor would need to be insulated.
/ Electrical Question #12
im saying you can run 2 hot wires to a 220V device and then ground the device and be properly "protected"
ie my AC compressor outside has 2 black "hot" wires running to it, and the metal frame of the unit is connected to a ground rod next to the unit.
a 220V device needs no ground/neutral to run properly.
/ Electrical Question #14
Well the same is essentally true for the power run to the building (10/2) with the cavot that it needs to be "terminated" in a sub pannel that has a dedicated ground (ie a new ground rod at that sub pannel location) Last i checked code dictated that each subpannel have its own dedicated ground. (ie new ground rod)
in other words if you DID run 10/3 with a ground/neutral and terminated it in a sub pannel, then the pannel would still need a dedicated ground dispite the fact you "brought one along"
make sence?
/ Electrical Question #15
A ground rod does not replace the grounded (neutral) conductor. Which is needed for 110v power and lights.
/ Electrical Question #16
while technically you are correct,
in practice the lights will still work. (but your "socket" voltage would varry as the ground potential changes due to gound conditions)
/ Electrical Question #17
Yes it will work. But it is not safe. Say you were digging outside of your building and you noticed you cut the wire to the ground rod, you reach down to see how bad it is and.............................lights out literally.
/ Electrical Question #18
A ground rod gives lightning a place to go. It will serve no other purpose. A ground rod should never be used to ground a piece of equipment. If you do, I'll be sure to send flowers at a later date if any short ever happens in your compressor.
/ Electrical Question #19
I see I have to consult the big book on code but I'm sure the ground rod at the sub panel is the neutral. Even if you cut into the cable in the ground it will trip out at the main panel because your feed to a sub panel starts at a breaker that is grounded. That said if you reach down and grab the cable regardless if it 10/3 or 10/2 with a bare hand your gona take the hit. same with your grounded compressor. Electricity will take the shortest path to ground. in this scenario that would be you, also if I may add if you hit a cable and grab it with a bare hand Shame is on You. You are correct that lightning will follow this path but that is not the only reason to ground your panel. In order for electricity to work properly in the US anyway neutral/ground is designed in all are tools, appliances, and ex cetera
/ Electrical Question #20
I am pretty sure that by code the sub panel needs to be grounded back to the main panel, only a main panel can have the ground rod attached to the ground bus. Otherwise you would have a ground loop (bad things can happen).
This is the way it was explained to me by my electrician friend, when I tried to hook my old barn up to my new barn (new 200A service there), I was going to ground the old barn using the existing ground rods and he told me that was a big NO NO. So, I ran 2G wire (2 hots, 1 N, 1 G) for a 100A subpanel.
You might want to check the NEC book to make 100% sure. If you do go the 10/2 route, you will have to put colored tape on the white wire as it is no longer a neutral wire, put something like red electrical tape on both ends. Personally I would just run the 10/3 or something bigger depending on your load requirements.
Derek
2017 VOLVO VNL64T TANDEM AXLE SLEEPER TRUCK (A59905)
2017 VOLVO VNL64T...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
2020 Chevrolet Silverado 1500 Pickup Truck (A59230)
2020 Chevrolet...
2012 Ford Transit Connect Cargo Van (A59230)
2012 Ford Transit...
2012 SOUTHERN  130 BBL VACUUM TRAILER (A55745)
2012 SOUTHERN 130...
2003 Dodge Ram 1500 Pickup Truck (A60352)
2003 Dodge Ram...
