Robert_in_NY
Super Member
- Joined
- Aug 1, 2001
- Messages
- 8,588
- Location
- Silver Creek, NY
- Tractor
- Case-IH Farmall 45A, Kubota M8540 Narrow, New Holland TN 65, Bobcat 331, Ford 1920, 1952 John Deere M, Allis Chalmers B, Bombardier Traxter XT, Massey Harris 81RC and a John Deere 3300 combine, Cub Cadet GT1554
I have a Kubota M8540 Narrow and am going to hook up an electronic sprayer control for my airblast sprayer. Currently my sprayer has no electronics and the new controller is a TeeJet brand. I have no problem hooking everything up but what I am trying to find out is this, the controller calls for a maximum draw of 10 amps. I have a 30amp socket inside the cab (takes a special plug I would have to buy from Kubota). It also has a standard 12v outlet like you would have in a vehicle but I don't recall the amperage on that one. I would like to set this up so that I can plug it directly into one of these outlets instead of hooking directly to the battery. I don't believe there would be a problem hooking into it since the controller has its own fuse built in but wanted to run it past you guys first before I buy a plug end.
I need to check the amperage on the one plug again but I don't know if its rated for 10 amps so would the 30 amp plug work for powering my controller system?
