xmariner
Bronze Member
Subject tractor: XR4040C.
A couple of weeks ago I moved some cows for a neighbor (2 short trips) - instead of hooking the stock trailer to the truck I chose to do the move with the tractor.
While on public roads, about 15 min. per trip, the hazard lights were used. When I was returning to the barn I noticed the hazard lights no longer worked. I finally got around to checking the fuse (assuming that to be the problem) - NOPE. Tried 2 different fuses same results. There is nothing wrong with the original.
All of the lights work except the hazards. I have not pulled apart the console beneath the steering wheel to gain access to the switch.
Any thoughts as to probability of a bad switch or possibly some other component gone bad.
Thanks, Mark
Thanks, Mark
