Electrical Problems on Jinma 254
/ Electrical Problems on Jinma 254 #1
RoddyMac
Nanaimo, BC
2005 Jinma 254
I'm having troubles with my Jinma 254 2005 model tractor. My guages don't work now, and even my light switches. Where do I start? Fuses all ok.
/ Electrical Problems on Jinma 254 #2
Instrument cluster or individual gauges?
//greg//
Instrument cluster. yet...once in a while they actually work. Intermittent. But more often than not there's nothing.
/ Electrical Problems on Jinma 254 #4
Bad connection at the positive, negative (ground), or in the clusters circuit.
Chris
/ Electrical Problems on Jinma 254 #5
Here is a schematic: http://www.tractorbynet.com/forums/...28-jinma-284-electrical-schematic-2005-a.html
I would start at the fuse panel and work toward the gauges. There is a large modular plug that connects all the wiring coming to-from the fuse block. All of the gauge circuits and all of the lighting circuits share a common ground point. If I recall correctly it is located on top of the fuel tank and bolts to the chassis there. I think there is also a modular plug at that point but I will have to go look at my tractor again to refresh my memory.
Good luck.
/ Electrical Problems on Jinma 254 #6
Insects and moisture create problems in those instrument clusters. I've found nests in the pig tail connectors that - when wet - short individual wires. And once wet, corrosion starts to set in. I recommend you start by pulling the cluster and do a good cleaning of both halves of the connectors.
//greg/
/ Electrical Problems on Jinma 254 #7
I like to:
Inspect, clean, and tighten all grounds.
Disconnect and reconnect all connectors 2-3 times each.
It is fast and often effective, and amounts to a tactile and visual inspection of the entire system. A person doesn't have to be particularly knowledgeable about electricity, so most people can do the work.
/ Electrical Problems on Jinma 254 #8
I know it has been years since this thread but my Jinma 254 is now doing the exact same thing. Did you ever determine the problem and fix? Thank you!
2025 32in. Mini Excavator Bucket Attachment (A64553)
2025 32in. Mini...
Quick Attach Concrete Mixer (A65579)
Quick Attach...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Wolverine SBM-12-72W Skid Steer Sickle Bar Mower  (A62679)
Wolverine...
2022 SANY SY50U EXCAVATOR (A63276)
2022 SANY SY50U...
