Electrical problem with interestering symptom
   / Electrical problem with interestering symptom
Thanks to you guys who responded yesterday. Sorry for my slow reply, but I just got back into town to use the library computer. Re: CaptPicky starter question, it sounded like the starter was kicking in, but I chickened-out when the sparks started flying, and pulled the screwdriver before much happened. I did try several times after that, but nothing happened, which is why I thought in my second post that I may have blown a fuse. I checked them and they were all okay. Another fella called me and was quite helpful and suggested that I try jumping from the incoming positive terminal on the solenoid to the small starter-switch-wire terminal on the solenoid. When I tried that last night nothing happened, but I did slip once and accidently bridged from the big positive terminal to the big negative terminal, which caused the starter to kick on just as it had the first time I tried it. Being completely confused, I quit at that point without trying to start the tractor, until having a chance to check what you guys said over night. Hosspuller, thanks for the possible reset explaination. I also appreciated the warnings about blowing the battery. I would have been really pissed getting a face full of battery acid, especially knowing that there were all kinds of safety goggles laying on a shelf right behind me. Thanks for the continued help.
   / Electrical problem with interestering symptom #12
Does this circuit have a circuit breaker in it.It sounds like it has a self resetting breaker.If it's not too hard to do i would remove the starter and check it for a short.If it checks good then go back from the starter and check every part for good connections and make sure they are doing what they're supposed to.
2017 Ford F-550 Bucket Truck - Power Stroke Diesel, ETI 40 Boom, 45 ft Working Height (A56438)
2017 Ford F-550...
2020 INTERNATIONAL MV607 (A58214)
2020 INTERNATIONAL...
402 (A52706)
402 (A52706)
2018 JOHN DEERE 844K-III AG HANDLER WHEEL LOADER (A60429)
2018 JOHN DEERE...
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
2016 CATERPILLAR 259D SKID STEER (A60429)
2016 CATERPILLAR...
