Electrical Problem; Probably Basic
/ Electrical Problem; Probably Basic #1
buckshot22
john deere M
I have a '48 M tractor. Ran when I bought it a few years ago and has been running well until recently. Matter of fact it's a work horse of a tractor.
Month or so ago seemed to lose some power. Now won't start.
Checked a number of things and bottom line there is no spark at the plug. Changed all the usual electronic suspects. Checked the coil (6 volt). Primary was 1.1 ohms and secondary was 9.5.
With switch on I get voltage to the coil via wiring harness.
Any ideas? Appreciate any help.
/ Electrical Problem; Probably Basic #2
G'day check you have power to the points when they are open, if so then sit the cap end of the coil lead near a good ground and with ign on open and close the points with a screwdriver and check for spark that will tell you if your coil is working or you can just sit a plug lead near a ground and with distributor cap on get someone to crank it over and see if you get spark to the plug.
Jon
/ Electrical Problem; Probably Basic #3
If it has a condenser I would replace that. Check for good clean bright connections at the coil terminals and in the distributor. Coil and plug wires can look ok but still be defective. I had a cracked distributor cap stall me along side the freeway in a car one time. Once it got dark enough I saw the spark going to the base of the distributor. I had the old one from the last tune up in the trunk. Threw that on and drove away.
2023 John Deere 8R 280 Tractor (A63109)
2023 John Deere 8R...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
STARCRAFT BUMPER PULL TRAVEL TRAILER (A63569)
STARCRAFT BUMPER...
Fair Oaks 10'  Multigrader Blade (A64047)
Fair Oaks 10'...
PEERLESS 10 BALE COTTON WAGON (A63745)
PEERLESS 10 BALE...
2024 CATERPILLAR 68" HYD 4IN1 BUCKET (A62129)
2024 CATERPILLAR...
