Electrical Power in the North 40
   / Electrical Power in the North 40 #1
Tom_Veatch
Platinum Member
Wichita, Kansas
Yanmar 2220D
Occassionally I find a need for some electrical power out in the boonies and, as an alternative to hauling around a portable generator, was thinking about installing a Power Inverter - something like a Coleman PMP2000 (2kw, modified sine wave) - in the electrical system of my Yanmar 2220D. Haven't located the "perfect" place to put it on the tractor, nor have I acquired an inverter, but it seems like it would be an ideal solution for those times that a little 110 AC is needed and the longest available extension cord is a few hundred feet too short.
Has anyone here done such an mod, and, if so, what has been your experience with it? Would it be worth a couple of hours labor and a couple of hundred dollars.
Don, Thanks for the pointer. I knew someone had to have thought of doing something like that before me.
   / Electrical Power in the North 40 #4
I have seen 12v battery jumpers/starters that also contain its own inverter and sometimes even an air compressor. I looked at one at Sears for around 80 bucks. This is a rechargeable battery pack and would not have to be hooked up to your tractor.
2010 Gleaner 9250 Draper Head  30' with Crary Air Wind System (A51039)
2010 Gleaner 9250...
71067 (A49346)
71067 (A49346)
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2019 INTERNATIONAL...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
