Electrical Plug In & Fender Cover
   / Electrical Plug In & Fender Cover #1
Jim in NB
Northern New Brunswick, Canada
Kioti DK45SE HST Cab
Hello:
I was wondering if someone knows what the plug in located near the winshield washer jug was intended for? I checked it for power and it is live when the headlights are turned on. I thought it might be a good place to take power for a rotating light.
Also, there is a small cover bolted through the top right rear fender... any ideas on what this was intended for?
Jim
   / Electrical Plug In & Fender Cover #2
Jim
I looked at my shop manual and they show a 3 wire plug with the fuses marked source 1 and source 2 . They dont say what the plug is for or where it is located . How many wires are at your plug ? It might also be for a license plate light , but they dont show a plug for it
Mark
There are 3 wires. Solid black, brown with white and white with yellow. This connector is in two pieces and the removable piece looks like it could be custom wired.
   / Electrical Plug In & Fender Cover #4
Kim Chee warmer?
   / Electrical Plug In & Fender Cover #5
Jim
I tried to scan the diagram and todays technology got the best of me. The wire colors did not match , except for the black which it shows as ground. I think what it shows is 2 dedicated circuts from the fuse box , and if you find 2 fuses marked as source or spare , try pulling the fuse and check for voltage at the plug . They show as 20 amp fuses on diagram . Best of luck ! Mark
Thanks Mark. I will have another look on days off. Do you know if the cab was pre wired for a beacon? There is a fuse in the slot (in the panel to the left of the seat) that is marked "beacon" and I will try this one as well. I think there is also a panel in or near the steering column and this one may have a fuse marked "source".
Jim
   / Electrical Plug In & Fender Cover #7
Jim
Yes they do show a beacon and wiring and says for euorpe , and shows 2 or 3 wires at the beacon , hard to tell . Do you have a switch for the beacon ? Good luck ! Mark
No there is no switch but here are a couple of covers next to front and rear wiper and work light switches. I am going to check with the dealer on Friday and see what they say. Thanks for your help.
Jim
No luck from the dealer. He does not beleive it was prewired for a beacon and is not sure what the rear plug is for.
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
Hydraulic 3" Water Pump (A50121)
Hydraulic 3" Water...
2011 Ford F-150 Platinum 4x4 Crew Cab Pickup Truck (A50323)
2011 Ford F-150...
Bush Hog 2820 (A50120)
2014 Kia Sedona Van (A50324)
2014 Kia Sedona...
