Generator Electrical Engineering Question
/ Electrical Engineering Question
Soundguy-I can up the rpm from the tractor to get 60 cycles. However the advice from Generac (thanks hr3), on the older generators was to let the cycles drift down a few cycles to get the voltage in a better range. At 60 cycles, I was in the 257 to 259 volt area. My no load was 253 volts this time at 59 cycles (within 10%, but still high too). This is the Niagara Power unit we discussed about 5 or so years ago.... made by Generac.
Thanks,
David
/ Electrical Engineering Question #72
With all of this knowledge on board I have two questions.
How are all of the generators that are on the grid put and kept in phase?
What is RMS? Root means square, Root and square of what?
Many Many Thanks, Scott
rms is a way of measuring voltage. IE.. average, rms, peak, peak to peak.
think of rms as a way to compair to equivalent dc volts, and the work you can do.
( net exact.. but a good quickie answer without 6 pages of electrical theory )
soundguy
/ Electrical Engineering Question #73
Thanks,
David
wow.. that's rough.
I have a pto genset that can throw 60 cps and 239vac at the same time, under load...
actually makes cleaner power than my utility according to my graphing o scope meter with time comparison...
capacitve reg to boot...
soundguy
/ Electrical Engineering Question #74
Simply speaking, the root-mean-squae (RMS) value of an alternating voltage is the quivalent d.c. voltage that can deliver the same amount of eregy to a resistive load.
All the generators are "phase locked" togeteher. It is the same principle as synchronious AC motor running at virtually constant speed regardless of the load. There is one "leader" generator in the system that maintains the frequency and the rest of generators are running in so called "droop" mode. If the grid slows down even a fraction of Hz the droop generators will increase their contribution to the grid to add more power and vice versa. In other words the droop generators are controling power not frequency.
/ Electrical Engineering Question #75
Agreed, RMS (root mean square) is a way of expressing the sine wave form of AC to a comparable DC value for power purposes. It is 70.7 percent of the peak voltage. It is what multimeters actually measure unless specifically set-up to measure peak. Wind mills are unable to generate at 60 hz, so the unstable AC is converted to DC,like any power supply. Then digitally reproduced into a AC waveform at 60 hz. Any store bought DC/AC inverter does the same thing, and a digital O-scope can actually see the stepping of the waveform and the output of the digital -analog converter reads like this.. 111111111100000000001111111111000000000011111111110000000000
The number of ones and zeros depends on the clock speed of the chip, but the cycles are 16 milliseconds. (60 hz.)
Sorry for the long winded trip down electrical/electronic theory lane, but I love this stuff.
/ Electrical Engineering Question #76
I am not trying to change subject, would just like to learn.
"It is 70.7 percent of the peak voltage."
Does this percent increase with increase of frequency?
Scott
/ Electrical Engineering Question #77
Scott
No. For a sinewave (and most are or close to it) it is 70.7%. It does change with the waveform shape. If it were a square wave it would be 100% of peak voltage.
/ Electrical Engineering Question #78
Think of the grid as a giant nationwide electrical circuit. Some motors can also generate electricty by spinning their shafts... Here's the connection... A generator needs to be in sync with the grid, or else the grid which is much stronger than the generator will drive it instead causing damage to the turbine. Once connected, the electromagnetic field will keep it in sync.
/ Electrical Engineering Question #79
Right on. Basically they adjust the field of any individual generator to put out the power they want it to. Once they are synchronized they stay that way.
/ Electrical Engineering Question #80
Mbohunter. "the grid, which is much stronger than the generator will drive it"
and we now have a synchronous condenser, which is used for VAR support .
The story goes on...
2011 Chevrolet Express 2500 Cargo Van (A59230)
2011 Chevrolet...
2020 SAVANA 3500 16FT BOX TRUCK (A59906)
2020 SAVANA 3500...
Bradco 6HFC Hydraulic Trencher Skid Steer Attachment (A59228)
Bradco 6HFC...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
Pat's QH and hydraulic top-link.
Pat's QH and...
Case Axial-Flow Combine Wheels NO RESERVE (A61307)
Case Axial-Flow...
